If I have to increase the normal size of twin & earth cable in a radial lighting circuit to 4mm², do I also have to use 4mm² cable to the wall switches because one is not allowed to reduce the cable size from junctions?
The reason for the increase in cable size is that I put some 12V transformers for sets of halogen lights along the circuit and the current increases, if I am correct in adding the current of each transformer and its lights to the total current in the circuit. I am assuming that I am allowed to use 2.5mm² cable on the output side of the transformer (this cable satisfies the current capacity needed on the 12V side of the circuit)
There are two situations: switches operating lights in the circuit at 230V and the switches operating the 12V lights
