Hi guys, is 1.5mm ok to use to take a spur off another socket to run a fridge on? And is a 20amp isolation switch suitable for an electric shower? Cheers in advance.
depending on the loads and cable derating factors.
littleleaks said:1.5mm ok to use to take a spur off another socket --
and also said:-- is a 20amp isolation switch suitable for an electric shower?
starspark
not good practice i would install an fcu. but in theory if you have a 5A socket outlet you are restricted to the load that can be attached. but there are no load sizes hence my very vague response.
So your saying 1.5mm is ok to take directly off a socket as a spur??
Ok so 2.5mm is it for the spur, anyoe want 25meters of 1.5mm ) The shower will be between 9 and 10kw, customer has not yet bought it. The current iso switch is upstairs but the shower is downstairs so I am wanting to put a new iso in. If I buy the highest rated one then I ought have no problems?
starspark
