Cable sizing
Usually at least 4mm2 for a 32A radial, and even then it depends on other factors.
OK, so, I will use 2.5mm2 "ring", and each room separately, so say 3-5 wall sockets, and fitted with a 20A fuse on the consumer unit?
But the kitchen : would that require beefier cabling as we have toasters, fast kettles, coffee makers, air fryers etc? Can I split the kitchen into two, so use 2.5mm2 still, but in two separately fused circuits? And have the W/M, D/W all separate?
WILL YOU PLEASE CONTACT YOUR ELECTRICIAN, THIS FORUM IS NOT THE PLACE TO BE HAVING THESE DISCUSSIONS.
FHS man, which part of "No one other than an electrician on site can answer your questions " don't you understand??
