came home to low water levels in two separate toilets
5 Jun 2013
Maryland
i came home to abnormally low water levels in two separate toilets on the first floor of my home. after flushing one of the toilets (with no solid matter in the toilet), the water filled to the brim and started to overflow until I turned off the valve manually. several hours later, the water level in that bowl is back down to an abnormally low level. i'm too afraid to even flush the second toilet for fear that an overflow will happen again. when i went upstairs, the water level in that toilet seemed normal. what is going on?
i came home to abnormally low water levels in two separate toilets on the first floor of my home. ?
That`s the Ground Floor here in the UK ;) still a blockage down the line somewhere - a job for Roto Rooter
i don't have a septic tank.
if it is a blockage in the sewer line, why would it only affect only 2 of the 4 toilets in the house?
