Hi. I wonder if anyone can help. I have a T5 fitted with a 70Ah leisure battery. I don't have a hook-up but rely on a 100W solar panel which delivers 5.35Ah at Pmax via a solar controller. The only electrical device I use is an Isotherm fridge which is 72 W and draws 6Ah off a 12v battery. I turn the fridge off overnight but have 2 issues. If I turn the fridge on when the engine isn't running, the van electrics go totally dead. They will only come back to life when I run the engine for a period. I have also noticed that if I leave the van during the day with the fridge running, I sometimes get back and same thing - electrics totally dead, even when van is parked in full sun. Clearly my panel is not generating enough power but surely the leisure battery should have enough in reserve to keep the fridge going during the day when supplemented by the panel. Also, what is happening here? There is no cutout in the system. Is the battery somehow shutting itself down? If so, this can't be doing the battery any
good.
Any suggestions? For example, can I buy a standalone solar panel to plug into the 12v socket and supplement the roof mounted panel during the day?
Thanks, Rob
good.
Thanks, Rob
