- Joined
- 2 Jul 2010
- Messages
- 237
- Reaction score
- 4
- Country
Thanks for all your help. If the pliolite paint is acknowledged as a solution to iron ore weeping from painted pea shell pebbledash it seems that the "All Seasons" option is the way to go. Has anyone actually used this type of paint on pea shell pebbledash prone to iron ore weeping and checked the finish say 6 years later to see if there had been weeping?
Subject to using the "All Seasons", for a first coat would I exceed the dilution instructions on the tin or stick with the recommended dilution of 1 part thinners to 10 parts paint? This dilution ratio was taken from the dulux system info pasted below:
"Seal new or bare surfaces with a thinned first coat of All Seasons Masonry Paint (up to 1 part white spirit to 10 parts paint) The normal finishing process is 2 full coats of Dulux Trade Weathershield All Seasons Masonry Paint. On previously painted surfaces in good condition, where similar colours are used 1 coat may be sufficient."
Rgds
Jack
Rgds
Jack
