NO, not EVER. All screwed connections must remain accessible. There really should be no reason why any junction needs to be hidden. If it really must then you'll need a "maintenance free" junction box like this
It is the branch cable which is the 'spur' whether fused or not.
The accessory containing the fuse is a 'Fused Connector Unit'.
This is sometimes called a spur by those who should know better but it is not.
What are you planning to connect at the end of the spur?
You may not need an FCU in a prominent position next to the socket. It could be positioned elsewhere.
