It all started two months ago, moved in to a new property, boiler working fine for 2 weeks, then it has been working intermittently since.
Plumber came and diagnosed ignition pcb. Replaced it - no joy. Removed and put old one back in.
Then diagnosed main pcb, cost of £170 plus fit. I didnt want to spend that much so got the board reconditioned with cet in watford. He came back and fitted them -no joy!
Then diagnosed it as the temp sensor, replaced - no joy, again.......
He spent ages on phone to alpha tech team, ran a lot of tests for continuity etc. The only thing that he and alpha think it could be is the main pcb. They want to try a new one.
Sometimes the boiler will work fine all day, sometimes not at all and sometimes randomly.
I thought it may have been a loose connection, because after fiddling with the connections on the boards i got it to work a few times, but this does not always proove succesful. Waht are the chances?
Another part of the problem is that sometimes when hw is working it runs at below temp even when turned up high.
Any help will be much appreciated.
Interesting that you say this is a good boiler, not what my plumber said!
Cheers
