DIYsaster said:another thing to consider is that even though problems like dry joints CAN be repaired, the rest of the board is still X years old and whats to say another component won't fail on it in a couple of months. i work for a BIG gas company and we do not use recon parts for that reason.
Component failures generally occur in the early days, after this component failure, except power handling components, is rare. How often do you change your television PCB?
Mostly recon parts are not used because new ones are not much dearer, and it's easier to get it replaced if it fails early.
my advice would be; be SURE it IS the board first, go for a complete new one-i know it'll hurt your wallet, but at least you will know it'll last.
It may fail fairly soon, though you would get a warranty repair for this, except joint failure is a longer term problem, so it may be out of warranty before it appears.
