I’m not sure I understand what you mean; yes you can cap the 3” pipe (are you sure it’s 3”?) but only if you fit a Hepvo valve;Can I not just cap that 3 inch pipe after it has picked up the bath and basin waste.
Bet it won`t - not dropping into a 3 inch - it`s not correct - but I`ll lay £5 it don`t syphon - if it does the £5 can go towards the hep V OIf you just cap the pipe off you will start siphoning the basin trap & be back to square one
Because you’re running two sanitary appliances into one pipe which is not good practice. Ideally you should have individual stack connections for each waste but even then there are maximum lengths for each size of waste pipe before you need to vent the branch. Usually emptying the bath will siphon the water from basin trap (but it can happen the other way around); air in the pipe is not replaced as the water flows down so it sucks it in through the weakest point which is the basin trap, pulling the water seal with it = gurgling; blip blip blip noises & drain smells.Why would it need another vent though. I thought one was ok at the top of the stack?
Yes, normal waste run is 40mm but high flow showers etc are 50mm; not sure if you will get an AAAV to fit 82mm, what size is the waste pipe from your basin trap?Yh its 3inch 82mm so is a funny size to get a fitting for.
Maybe not with a 3” pipe; it’s unusual & I’ve only ever run 50mm max unvented but the OP also has two appliances on one pipe so it will also depend how much water is in the bath, how long the water flows & weather the basin trap is at the blind end or between the bath & the stack. If there was not previously a problem, I’m wondering why the end of the pipe has been left open, it must smell something orrible.Bet it won`t - not dropping into a 3 inch - it`s not correct - but I`ll lay £5 it don`t syphon - if it does the £5 can go towards the hep V O
