AMEdinbugh wrote
Yes their is a simple answer to this problem.
The thermostats you fit to control the pool temperature and the treadmill tank temperature energise motorised valve's to open , which in turn energises the boiler through the end switches in the motorised valves.
What type of thermostats are you using and where do you intend to locate them ?
I am hoping there is a simple (and therefore clever) answer to this conundrum to allow the boiler to continue supplying the heat exchangers even when the desired room temperature has been reached.
