Hi, i have a a 220v light fitting, holding 3 r80 60w lights, switched from the wall.
id like to add a reading/task light, like a 12v recessed spotlight to the ceiling.
can i wire this direct from the ceiling rose by adding a transformer. so that the same wall switch operates both the 220v and 12v lights?
can i add a pull cord switch to the new run, so as long as the main 220 lights are on i can turn the 12v on or off with the pull cord?
can i add a remote control light switch instead off the pull cord switch to the new 12v run to have the same setup? (control both from wall and control 12v with remote so long as 220v is on).
