Lighting - Do I have to have string hanging from my bathroom ceiling?
Thought they had gone bust.
Ah yes (from another thread)
Their website offline since approx. December 2018, and hadn't been updated for years anyway - last news item on it was from 2012.
Their twitter account and Linkedin profile both deleted.
The company that traded as Taptile was dissolved on 24 May 2016, over 3 years ago.
https://web.archive.org/web/20180821002838/http://taptilecontrols.com/press.htm
https://www.ribaproductselector.com...of-gpeg-international-ltd/27461/overview.aspx
https://beta.companieshouse.gov.uk/company/05355242
Maybe people realised that they could use standard switches anyways!
I too have survived operating a switch with wet hands. Not only in a bathroom. Millions of people are quite happy to operate switches in kitchens, with wet hands and don’t give it a thought.
Why aren’t kitchens populated by dozens of ceiling pull switches??
People aren't generally wet and naked in a kitchen.
Most white switches are IP22 rated, so not a concern
Whilst I personally have no problem at all with the concept of light switches in a bathroom, in terms of the context of your comment, does IP22 have any real bearing on the effects of condensation (whether running down and wall, and potentially 'behind' the accessory, or condensing actually within the accessory?
Kind Regards, John
Look at the Qinetik range from TLC.....totally wireless switch that you could have on your shower screen if you wanted
Appreciate the replies. My options seem to be…
use a normal 240V dimmer and risk a possible ‘tingling’ and at worst electric shock
use a simple wireless on / off switch
use a wireless fancy dimmer with half dozen buttons
I guess I really want a standard dimmer switch, if I could find an IP44 one that would check all the boxes
You'll be fine with a normal 230V dimmer. Certainly a very low risk of electric shock - the potentiometers are usually plastic shaft, and you can choose one with a plastic knob if you're concerned.
Ok thanks a plastic dimmer it is :)
