hello
can some one (hopefully ex BT worker ) answer this !!!!!!!!!
can i cut the incoming BT cable ,were it is fixed to the brick work outside and comes from the pole , and put in a jointing box ,then run new cable to master socket ???
And is the incoming line fused at the exchange at all ??
so if i cut them it will cause a problem or notify BT it has been done .
