I've just bought a new grundfoss 15-50 pump, as recommended by people on here. I may have a problem though. Reading through the instructions is says that pumping downwards is not recomended although the old pump did. It also says that the cold feed from the expansion tank should be on the return side of the boiler and the vent should be on the flow side but both these are on the flow side of my system. here is a drawing of what my heating pipes are like now
If i put the pump pumping downwards its label will also be upside down im wondering if the system was fitted correctly as the boiler instructions say that the cold feed should be inverted - it isnt - and it should be on the flow side of the boiler but the pump says opposite
can anybody tell me what is correct ? thanks
