grundfoss state that this is a non prefered option and should only be done if there is a suitable means of venting air directly before the pump. The reason being that owing to the design of the pump body, air can become trapped.
Ideally the feed/vent wants to be on a horizontal piece of pipework prior to the pump, the horizontal pipework preferably in a larger diameter. Usually you will find that it goes straight up from the floor and the tee to the pump goes horizontally from it. Not the best as this reduces the likelihood of the air seperating from the water and being vented.
Another option is if an air separator (aerject etc) has been used. This are usually about the size of a small can of beans and in your case will have three pipes going from it. Again this slows up the velocity of the water and allows air to seperate more effectively.
Having said all of this if you've got 20 yrs from your previous pump I don't think you've got too much too worry about
