- Joined
- 28 Apr 2004
- Messages
- 7,917
- Reaction score
- 761
- Country
The devils workMy house has Paramount everywhere upstairs. There is not a lot of wood in those panels.
Just to add, I have used these for our (heavy) bathroom cabinet with tiles on the wall.These are stronger:
Heavy Duty Plasterboard Fixings | Cavity Wall Fixings | GeeFix
GeeFix ultimate heavy duty plasterboard fixings, cavity wall / hollow wall anchors for heavy objects. Works with materials between 3mm & 75mmwww.geefix.com
House is couple years old, moved from an older house with wooden studs which was handy for hanging up heavy items.Google neodymium magnets, they will identify the position of the studs assuming they are steel, even through tile. Not sure I would risk anything weight bearing on them unless perhaps on a wooden batten which had been fixed to the plasterboard in between the studs as well on them, so spreading the load. OOI when was the house built?
Blup
I always found butterflies a bit awkward to work with, much prefer umbrella fixings, need to buy a setting tool thoughI think somewhere in-between "sell the house" and "hang the cabinet on the tiles" lies the answer!
I wouldn't trust the tiles as I've seen so many scarcely stuck.
Butterfly toggles should do the trick.
Drilling a 1" hole through a tile is interesting, and I recommend checking youtube for reference before doing it. But it does the job.
Its a bit of a faff, and if the wall is thicker than expected, you may need a longer screw, but its certainly strong.
Does the wall unit use the same kind of hanging brackets as a kitchen wall unit?
If yes then, assuming that it is supplied with two small hanging plates, for the left and right, drilling a 1" hole may not work. Those hanging plates are often only a couple of inches wide. You can however purchase longer ones that will span the full width of the cabinet and enable you to drill several holes and distribute the load.
Cabinet Wall Hanging Rail 1m or 2m Heavy Duty Hanger - Debonair Joinery Products
Visit Debonair Joinery Products and buy 1M or 2M hanging rail kitchen cabinet cupboard wall mounting bracket hanger at just £3.49 excl. VAT. Take a look!www.debonairjoineryproducts.co.uk
Haha brilliant! I have, however, am thinking of a buying a cabinet which is a decent bit lighter at the moment.Sell the house and buy a proper one made of solid stuff.
Or tell whoever had the bright idea to get a bathroom cabinet to get on with fitting it.
More seriously, have you considered a floor-standing cabinet, or perhaps a few small shelves?
