I've seen some single phase installations with a 3 phase isolator.
No reason why not - if one wants to spend a fair bit more than necessaryI've seen some single phase installations with a 3 phase isolator.
Yes. Why else would I need a 3P+N isolator?
Sound like my arm would be twisted into getting a 'smart' meter.. urrrgh.you could buy and fit a suitable isolator, just screwed in place, and ask them to wire it in when they do the meter swap.
When I had my smart meter fitted last year, I asked for an isolator to be fitted as well.
The guy was happy to do it for free, but wouldn't have done so if I hadn't asked.
I think this is all baloney.Before the smart meter we could remove the fuse wearing appropriate PPE and often the seals were already missing so no one knew the wiser, but the smart meter is suppose to auto inform the DNO of a power cut, not sure if they really do that, but they should, so one can't remove the fuse as it would flag up as a power cut.
Yes, that's what the guy did.To do this, don't they need to pull the main cutout fuse?
Kinda like how they used to say that Tv Licence inspectors could detect whether the TV's on from outside the building in their van
Unfortunatly it didn't actually get used all that much, because asside from not being admissable in court, they found that the effort of the engineers designing the equipment was largely wasted, all they needed to do was drive one of the vans slowly down a street where not many of the properties were licensed on a Saturday morning, and they'd all be at the postoffice on monday morning tea break building a TV license..... So in the end, they did just start sign writing empty vans as detector vans, but that doesn't mean it couldn't be done, they had just found they didnt actually need to
In theory, yes - but given that I usually do not work on electrical installations other than my own (and certainly never on other 3-phase installations), it's probably unlikely that I would have a 3P+N isolator 'to hand' if I didn't have a 3-phase installationYou might just have a 3P+N to hand?
As an ex BT engineer...That was actually possible, and whats more they could tell what channel was being watched. Its possible to pick up leakage of the intermediate frequency from the local oscilator in the TV, and if you do it with a directional attenna you can pin point which house to some degree.
These days it wouldnt be quite so easy, the intermediate frequency would only give you the digital multiplex not the actual chanel, and I'm sure EMC rules mean less leakage from the local oscillator
As to the smart meters, yes, loss of power will be logged, but I think if its just a one off event and no other tamper signals are logged then its not worth the effort in following up who removed a fuse to change a DB, of course if someone was upto no good, I'm sure every logged event would be in a file for when they got done for it.
There is a difference between what its technically possible to do, and what its worth expending time and energy doing
