Can I replace an intermediate switch with a 2 way switch?
Status
Not open for further replies.
22 Jul 2006
Norwich
Hi all you brighter, more electrically wise people - I have a question - can I replace an intermediate switch with a simple 'ordinary' 2 way switch? I bought 2 switches, and realised when I took of the old switches off that it was an intermediate switch, ie had 4 terminals - namely L1 L2 L3 L4 - the replacement switches have 3 terminals - namely com L1 L2. Is it possible to take the four wires from the intermediate switch and put them in the 2 way switch, to save buying an intermediate switch (which it seems may not be available in the same style as the other new ones I've bought - genius huh?)
Also behind the switch, there is, as I'm sure you'd expect, my 2 red (power) cables and my earth cable.
Er, no. If you want this circuit to work as intended, you need an intermediate switch.
where did you intend on putting all the wires then?
you could use the two way or even a one way switch and a DPDT relay wired in change over configuration to replace the intermediate. Sometimes the only option if you need to match existing switches
Buy an intermediate switch! You know you need to! :LOL:
and the neutral to operate the relay comes from?
I thought about suggesting a 2gang 2way switch, a bit of DIY glueing the switches together with a piece of plastic so they both switch at the same time, wired as a change over configuration, then I thought better of it and didn't bother posting my suggestion :LOL:
Best buy an intermediate switch.
Of course you can do it.
But it won`t work as intended though.
Get an intermediate.
have an electrician fit it though
thanks for all the suggestions and responses - there seems to be an air of disagreement as to whether it can be done or not - so I've located a switch in the same style as our new ones and gone and bought an intermediate switch to save any further bother.
this way I can wire it as per the old switch
You've certainly picked an apt username, haven't you....
Breezer, with respect, I'm trying to offer the guy a solution to his problem rather than just saying (as you did) that it won't work.
Agreed you need a neutral for an intermediate, but the relay doesn't have to be located in the lightswitch, it could be somewhere else.
As I say, I'm trying to be helpful, your post (with the greatest of respect) was of no use to the guy whatsoever.
Please remember this is a DIY forum where people look for solutions to their problems. Your answer:
doesn't help.
To be fair you aren't the only one, but come on, let's try and help out a bit here, I see little point wasting both your time and the time of the poster just giving unuseful answers.
So, I still maintain he could use a relay - hopefully this will be useful to the guy, and if he wants further information I'll gladly provide it.
One of my customers broke their double socket. When I arrived, he thrust a 1G switch in my hand and was gob-smacked to learn that it would not be a suitable replacement, ie, he would not be able to attach his table lamp to it.
If a switch has four terminals, and they are all employed, why should anyone conclude they could replace it with a switch with fewer terminals?
Status
