Hi everyone. Would someone be able to give me advice about a problem I have with my neighbour please.
Two workmen turned up at my neighbours house yesterday and replaced a fence panel. The panels are a loose fit between concrete posts where the panels slot into a groove in the posts and are slid down into place.
The panel they replaced it with was 30cm higher than the old one which looked a bit odd when it was in place. My neighbour then came out and spoke to the workmen. The workmen then removed another fence panel which is opposite my kitchen window. They then swapped the new panel for the one they had just taken out. This meant that the new, taller panel was right opposite my window and as it was taller than the old one, blocked out more light. (see pic)
The picture I have posted shows the view from my kitchen window. As you can see the distance between the top of the fence and the car port roof is now 30cm less. I spoke to the workmen and asked them if they were going to cut the panel down to size. The workmen replied that the owner had come out after they had replaced the panel and specifically asked them to swap it with the one in front of my window.
I have also just found out that this neighbour also had big problems with the previous owner of my house (I bought the house a year ago) which resulted in her being arrested for criminal damage to some cars.
I have looked at the Planning Portal site and found the following: (see pic)
"You will not need to apply for planning permission to take down a fence, wall, or gate, or to alter, maintain or improve an existing fence, wall or gate (no matter how high) if you don't increase its height. In a conservation area, however, you might need planning permission for relevant demolition in a conservation area to take down a fence, wall or gate."
Link here:
http://www.planningportal.gov.uk/permission/commonprojects/fenceswallsgates/
I interpret this as meaning that you can maintain and replace your fence as long as you don't increase its height. You would need planning permission to increase its height.
I have contacted the local council planning department and the person I spoke to said the information I quoted from the Planning Portal site was wrong, in fact he said he had never heard of this. He also said that he would try and take a look at the fence but said that he and the council would not take any action.
Does anyone know if the information on the Planning Portal is correct?
Any advise on what to do before my neighbours behaviour gets out of hand would be appreciated.
Link here:
