Hi all,
This may seem like a silly question but I wanted to check before I start pestering the architect with yet another stupid idea!
We have ruled out a full loft conversion because there is only 2.3m from the top of first floor ceiling joists to the bottom of the ridge and quite frankly we don't feel we would get our money back on a full loft conversion on this particular property. However, I did have an idea to convert part of the loft to create a mezzanine to the master bedroom onto which we could do a quirky en-suite.
So the way I thought it could work would be to remove the ceiling over the master bedroom to create a vaulted ceiling space up into the roof, insulating and boarding it out with some nice timber reveals. We could then carry out necessary strengthening work to the ceiling joists over the bedroom which adjoins the master in order to use that ceiling as a floor onto which we build an en-suite. There would be an end wall to this mezzanine at the far end only so it would in effect be a balcony overlooking the master bedroom. We could then run a staircase up to it within the master bedroom.
My question is, does this partial loft conversion work? Essentially if a loft floor sits over some of the ceiling joists of the first floor and runs the full width of the building from wall to wall but not the full length of the building as most loft conversions would (to maximise footprint) is this structurally possible? Does it need RSJs or steels at each end because it isn't running the full length of the building for instance?
Obviously I will work with an architect and structural engineer to confirm the details, I just want to know if there is anything obvious in this idea that would make it a non-starter.
