The soil and waste are sorted (not so many options there) so it's just the potable side. The incoming supply pipe is 32mm. What reduces that to a sensible diameter to start running pipe work? Most of the piping will be hidden and Im not averse to using plastic e.g. Speedfit. Do I need to buy my appliances (baths, showers etc) first to know the connectors or is it fairly well guaranteed that the fittings for any given bar thermostatic shower (for example) will be the same diameter and distance apart?
The other thing, and tel me if it's daft, but I have stacks of 16mm pe pipe (WRAS blah blah) left over from the UFH, and I note it's possible to get reducing couplers to go down to normal 1/2 and 3/4 fittings and 15mm compression ones too, so is it a really daft idea to plumb the house using this 16mm (bath excepted maybe) that reduces to 15 or terminates in a suitable 1/2 or 3/4 when it reaches an appliance? What to do for a manifold you ask? Well, I could buy a UFH manifold without pump if the flow rate could be dialled up enough...
i did catch reference to a thread here where a guy was DIY his plumbing and he mentioned pipe that is fitted inside conduit so catching a leak and running a new pipe was apparently easy. Is this common? Wise? Relatively cheap?
Another q, do speedfit do manifolds so you can get away without joints? I deliberately designed the house so all water consuming appliances are near each other so running a pipe from the utility to each isn't an arduous task..
