I bought a flat in a small development of 12 properties, each of which has an allocated garage.
The problem is that the garages were designed in the 1970s for 1960s size cars and as such, modern cars no longer fit.
This might not be such an issue except that we need to provide electric car charging and as some garage blocks are at 90 degrees to other blocks, you cannot park in front of your own garage as you block access to someone else's garage and thus, you cannot charge your car from that position.
However, there is lots of land. So one question is what would be the cost to build 4 x 3 wide garages.
The second question is whether we could use the existing 3 x 4 garages and convert them into 3 x 3 garages, needing then to only build 1 x 3 garage. I suspect the internal walls are supporting but is is cheaper to adapt or replace ?
