I have a Candy grand washing machine model GO 282 that has developed a spin problem. The speed keeps fluctuating like it's trying to get up to speed then cuts out, tries again and cuts out. It keeps going until the wash is finished. No fault codes flash up.
I tried the self test mode, fills with water, spins a bit, drains but it stops and all lights flash.
My thinking is a fault with the speed sensing? Problem is trying to determine if the sensor or the circuit board.
With my multumeter set to 2k ohms I get a reading of 0.47 which sounds a bit low?
Just looking for guidance.
It could be it's reached the end of it's life but if it's an easy enough fix I'm happy to get stuck in.
Cheers
Cheers
