After removing (and replacing) a radiator the pressure on the dial on the boiler has fallen to zero.
I've tried the two taps on the right hand side at the bottom (that are connected to the flexible pipe) and nothing happens. There is a screw on the flexible pipe which I guess controls the valve and I have tried it both fully in and out.
There is no noise of refilling and the dial stays at zero. Do I need to do something with the screw on the automatic air vent thing?
Any suggestions will be very gratefully received!
