Cast Iron Downpipe
29 Oct 2009
Lancashire
downpipe came loose at the weekend. Doesnt look like im gonna be able to refix using the current fixing.
as a tempory measure can I fit standard 68mm to the exisiting top & bottom sections?
Any special fittings that I may need?
what is your gutter made out of? if your connecting plastic to cast you will have to get an adaptor i find the rubber ones are good enough although they can be quite unsightly if you are using them on a period property and such
im due to get the whole lot replaced at the start of the new year. theres only one part of the guttering thats cast iron & thats the front downpipe, the rest is standard half round plastic.
all i want to do is replace the centre piece of the downpipe to plastic as a temporary measure until either a) i can get someone to fit the cast iron back on or b) when i get the whole system replaced.
can these rubber adpators be found @ B&Q etc?
yeah ull get em there but if you find an independant plumbers merchants they will be cheaper they are about £6 each here for that size it will be fine to use a length of plastic and two collars will last forever
