- Joined
- 15 Apr 2018
- Messages
- 300
- Reaction score
- 3
- Country
Thanks for the replyOver the distances involved cat5 will support 1G quite happily so shouldn't need immediate replacement, I'd not if it involves lifting loads of board etc.
You may also find that wireless coverage from one access point in the home office alone may cover the whole garden quite happily so whether it's worth running an additional cable to the summerhouse for another wireless access point or wired access is a tossup really depending on how easy/tidy the run is.
For the home office you can either run multiple cables back to the kitchen or one and install a small switch in the home office.
I didnt realise how cheap switches were! though the POE ones are slightly more expensive.
Evolving the idea slightly;
The cable that runs to the kitchen might reach the point where i will install the switch.
If this is the case could I install a cheap switch (merely to avoid putting a ethernet joiner in line) run a new external cable to a POE switch in the office which will feed the wap in the office and, if required, a wap in the summerhouse and a hard wired connection to the office
