Sounds like a good idea to me. I have installed floor boxes in a concrete floors before it was a messy job. I used an angle grinder to cut the hole. I would install a couple of tubes for future use though.
Sounds good to me. A flex from the ceiling would always be getting in the way.
By the way, Rocky, under what conditions can strobing occur? Is it when the rotational speed of a machine exactly matches the 50kHz supply of a fluorescent fitting? I only use fluorescent lighting in my workshops, and I've never seen a moving blade looking stationary.
