i have had extension built with 100mm cavity and fullfill 100mm cavity batons for insulation between facing brick on outer wall and thermalite block on inner, i have been told now i may need insulated plasterboard also to meet regs, does anyone know what thickness insulated plasterboards i will now need and if i have to use celotex or polystyrene insulated boards,
- I HAVE USED KNAUF 32 CAVITY BATTENS,
- Low thermal conductivity of 0.032 W/mK gives superior thermal insulation .
