Hi All
What is the standard wall detail with the new part L requirements please?
I have a 2021 design with 100mm cavity bats and thermalite inner skin. I understand that's no longer enough?
I guess the three options are:
1. 150mm cavity with rockwool batts
2. 100mm cavity with Kingspan
3. EWI or insulated plasterboard
What are most people doing? Can you fit a 150mm cavity wall on a normal 600mm trench? I need clay board which may make the trench requirement wider?
