I'm really hoping that there's someone on here with knowledge of installing cavity wall insulation - I have asked as many questions as I can, but I just don't have the building knowledge to proceed further.
I've moved into a traditional 1930s semi. It's got recent double glazing and a double thickness of (new) roof insulation - but when the wind blows, it's so draughty! I am desperate to have cavity wall insulation - but have run up against problems.
I have had the survey done, and there is a cavity wide enough to support insulation being inserted. However, the survey found some rubble in the cavity - I looked through the fibre optic, and it seems to be building debris/ small pieces of wood, which have fallen to the bottom of the cavity when the house was built. However, because of this, the company who surveyed say that they cannot insulate. They use the cotton-woolly type of insulation that is blown in at high pressure; and they say that any debris in the cavity will cause uneven 'filling', which in turn will cause damp patches.
But my house is cold! Please, can someone tell me: is the problem insurmountable? Is there another form of cavity insulation, e.g. polystyrene, that would work better? And where can I get it? I have repeatedly tried the energy saving trust for information, but they only refer to their approved suppliers.
Thank you very much if you can help!
