Hi, just a general question ,when a new house is being built is there a standard measurement of the cavity between the external and internal walls or is there a minimum/maximum range.......say the external brick is 100mm then cavity then internal block 100mm plus plasterboard and skim would you say the average thickness of a wall is 300mm -350mm
