The beams are, presumably, deeper than the joists, so the top of the beam would have to be higher than the floor joists in order to get the bottom to line through (set it half inch or so above bottom of joists).
As long as there is a wall over (presume there is, hence beam size!), then the beam can be hidden within the width of the wall.
Put joists on extended leg hangers, with sw blocking piece within the web of the beam, to stop the joist ends rotating.
This arrangement is slightly more involved to install, as it would mean needling the wall above the level of the joists, rather than using the joists themselves as needles, but it's not rocket science, or that much more expensive - I can't see how Nose came up with his EO figure.
