Ceiling Light all wires same colour, help!
i'm 99% sure those clear plastic covered things are a kind of crimp connector. i've seen them when modifying equipment before.
renegade74 said:
disaster, i've just fitted it, its three x 50w spotlights, tried it with one it came on fine so i attached it to the ceiling then tried it with all three & the main fuse box went bang! & now have no lighting at all in the house, what could i have done wrong!?!
How did you wire it? What did you connect where? Can you post a picture of the wiring?
I bet with the wires being too long he crushed them on the meatl fitting when screwing it to the ceiling
I pushed the wires back into the ceiling when I attached it. I attached the twisted wires to the neutrel & single wire to live & earth to earth. The fact that it worked with one bulb but not attached to the ceiling, but blew the main fuse with 3 bulbs and attached to the ceiling, I must have done something wrong, I better go to BNQ while I b4 it get to dark to see!
as i said since it worked before going onto the ceiling you must hzve shoted a wire, probabl;y on the metal bits
I suspect the cables have been damaged, or you left to much copper showing at the terminals. when you have screwed it to the ceiling, you have created a short, and a bang ;)
I hope you put some red sleeve or red tape on the non red live conductor ;)
Yes, you were too mean to employ an electrician.
You tried to do it yourself to save money and now you've discovered that you don't have enough knowledge.
Enjoy the dark!
Enjoy the dark!
Why learn to drive when u can just get a taxi.
If everyone had your opinion we'd all be living in caves.
I've already gained some knowledge today, I spent 65p on a fuse wire & have lighting everywhere else thank you very much. I'll try again tomorrow
Got it working now, thanks to those who gave me advice. The live wire did have a cut in it, maybe it touched the fitting when i pushed it into the ceiling so i sealed it with some tape.
Enjoy the dark!
Hm, like you were too much of a pratt to be civil.
