Hi all - would be very grateful for your advice on a problem I have.
I recently had a new ceiling installed in my flat. The builders did a poor job of skimming it, so I had another plasterer come and re-skim it. He had lots of good references, was experienced, etc.
Anyway, it turns out that he has made a total mess of the ceiling as well. It's probably worse now than it was originally. The problem is that it isn't smooth - there are lots of small scars/ridges/dimples all over the ceiling. WHile you can't notice this at night, in the the daylight it's obvious.
The plasterer came back to have a look and admitted that it wasn't up to scratch. It's a big ceiling and he said the plaster must have been going off quicker than he could get it on! Unfortunately, for various reasons, it would be impossible to have the ceiling skimmed again, which is probably what it needs given the number of defects.
My question is this - although the finish will never be perfect, would it be possible to fix the worst defects using easi-fill? I.e. put easi fill over (in some cases it might be quite a big patch) and then give it a rub down. I know that it will take a long time and be labour intensive to put easi-fill over all of the defects, but time spent on the job isn't an issue, I just need to get it up to a reasonable finish.
Or will using so much easi fill just make it even worse?
Any advice appreciated - am at my wit's end, can't believe two plasterers (both recommended) have got this wrong.
