Right so you have 4 speakers in that room. Which ones go to the left channel and which to the right?
simple
Thanks again. Since I cant afford the speakers just yet and I reckon i will need 6 gooduns and 2 average single speakers,
Decent speakers will, Yes. They'll each have three or four fixing points that worl like a vice to grip the ceiling board.Also, can I assume that the speakers will just hang on plasterboard and don't need any battens etc.
Speaker size (and hence the cut out diameter) depends on the make and the model of the speakers you select. Until you have decided that then no-one can tell you the exact cut-out size.Also, for purpose of selecting 1/3, 1/5 line, what diameter do i assume for these speakers?
Indeed. See tips here: http://www.satcure.co.uk/tech/wiring.htmPutting wiring in after a year or two is the most expensive and most disruptive way of doing things.
