fitted a celing fan/light combo in my lads bedroom, a straight swap for the celing rose etc etc, the unit uses a remote control to switch the light on and the various speeds of the fan.
Obviously the the original light switch isolates the whole unit....however so the fan isnt running all night when has fallen asleep with it running, I was thing of putting a "push to switch on timer" unit in parallel with the main light switch switch so when the main switch is off he can push the timer switch in and the fan will only operate for the preset time....
Aside from the obvious isolation hazard (ie the 2 ways of energising the fan/light) do you learned chaps reckon this will work.
I already have a push timer set at 20 mins on the fan in the main bedroom, but its not in parallel with the light switch, as the fan is standalone fan without a light, and the timer works perfectly.
