hi there.
have just removed a ceiling rose to fit a new light fitting.
in the light fitting there is a block for live,neutral and earth.this block is connected to the metal round fitting that is then connected to the clamp attached to the ceiling.the wire that connects to the bulb holder is white with a brown and blue wire attached to live and neutral accordingly at the block above.
from the ceiling i have the following wires coming down from three separate grey sleeves. three reds and three blacks.also there is one separate grey covered wire.?? i checked inside the light switch for the room and it would appear that this is that wire?? we connected the three reds to the live terminal and the three blacks to the neutral and the grey one to the earth initially.the light stayed on despite the switch being turned on and off. we have now disconnected this and tried the three blacks in to the neutral, the g separate grey into the live and the three reds in to the separate block provided.the light turns on for 2 secs then wont work.the fuse does not low either.can anyone help please??
