I removed an old skirting board and behind it was cement (which broke)rather than plaster.The wall above the skirting has plaster.Before I attach the new skirting board I need to replace the cement.What mix of sand to cement should I use?
I'd use battens then, so there's an air gap between wall and skirting. Give the battens a couple of coats of Cuprinol Green before fixing, and prime the backs of the skirting boards.
