Hi I have a fairly new boiler installation (since new extension). The builder suggested we upgraded the 20 yr old one with a newer more efficient unit as we were having major works. But also relocating it to the attic space. All fine....
I have a few problems however....
The heating is controlled by the app “the hive” and whenever you turn off the heating manually on the app, you can hear the system make a loud bang as if a valve is clamping off. This doesn’t seem to be coming from the boiler itself, but more from where the hot water tank is in the airing cupboard.
https://app.photobucket.com/u/Dundee_stokie/p/c9ff2cfd-6d80-4cb4-a97e-af82076987f5
Also, the pressure gauge loses pressure every now and again - does this indicate a leak somewhere? The pipe where the top up valve is always seems really cold and damp, could this be the issue ?
