central heating boiler oil pump
26 Mar 2011
Hampshire
I a problem with a noisy oil pump on 1980 trianco redfyre boiler. The pump is an electro-oil sp 272 t 305a made by electro-oil sweden. The boiler has now locked out so I need to find someone to refurbish the pump, I think it needs new bearings fitted. Does anyone know who might be able to do this or has anyone done it themselves? Your help will be greatly appreciated.[/u][/b]
I think your numbers are for the complete burner. The oil pump is only a part of this, and is probably made by Danfoss. It is probably the motor which is noisy and they are readily available from several stockists. Contact a local experienced technician for repair.
One of the Danfoss BFP range, I think...the complete number is on the side of the pump, with the letter L or R somewhere on there. This is the direction of rotation, and its vital you get the same one.
John :)
