Thanks everybody for your replies. Because the boiler continues to work once started, and it is winter, I thought of maybe waiting for a warmer spell of weather, and for the shops to open, before doing anything. I am inclined to think it is the pump which is at fault - I can detect no movement in the motor bearings, but when the fan is rotated by hand, several points of resistance can be felt during each revolution. I presume this is the pump - if the bearing had failed surely I would feel more of a grating? When the boiler is warm, it readily starts on demand. It is only when it is completely cold that I have to turn the fan by hand to free it up a bit. The application of heat from a fan heater helps. Could it be the capacitor is breaking down? The motor tries to turn, but doesn't seem to have enough power to overcome the resistance referred to above. what are the symptoms of a failed capacitor?
