Hi there, wonder if anyone can help/advise.
When I switch on the hot water...my radiators get hot as well (still have hot water).I was told that its most likely my 3 way valve which is a Honeywell V4073A1039. Firstly it has a little lever on the underside which has manual/Auto on it....Im assuming this should be in the Auto position?
Ok my next question is that if this could be the culprit..is it acceptable to just replace the head (Pt No.40003916-003) ie so I won't need to drain the system...something I would like to avoid if at all possible.My gut feel is that I should replace the whole thing (cost difference is negligable) as the actual mechanical bits may have wear/ tear....does anyone out there have any opinions?? Cheers AC
