Hi there!
I am wiring up a new heating and hot water system that is being installed by a plumber. I've recently moved into the house and I'm re-wiring it, with the appropriate building control inspections of course. I figured I'd save £680+VAT by doing the wiring for this new heating system myself.
So; I have a 3 channel programmer and there are 3 zone valves. One for hot water -- sealed cylinder, one for upstairs radiators, and one for downstairs UFH.
The UFH manifold and control panel, UFH zone valve and the programmer are under the stairs. The boiler (Rayburn 480CD) is in the kitchen. The hot water cylinder is in the loft.
The boiler requires a 3A fused spur, as does the UFH control panel. It would be possible to supply these from the downstairs ring main. But the attic has it's own ring main, and I assume it would be a bad idea to connect the heating junction box (Honeywell 42002116) to that supply. Seems wrong to do this from separate rings.
I do have space in my CU, so I did wonder whether I should have a dedicated ring (or radial) circuit for this stuff.
Any advice?
Thanks in advance,
Orval
Any advice?
Thanks in advance,
Orval
