Hi all, my heating is firing up ok but when selecting central heating the boiler does not fire up. I changed the 3 port valve for a horstmann valve but still have the problem, when you select central heating the valve moves to just past the mid way position but not fully across, if you then pull the override lever fully across the boiler fires up and you get heating. I thought it might be a faulty valve so tryed another identical valve and it does exactly the same. Any ideas ?
