Hi, sorry don't have a volt meter but have been doing some more investigation.
When the HW and CH are switched on at the same time, and I manually operate the CH 2 port valve the CH throughout the house gets hot. As soon as the HW turns off either from thermostat in cylinder or timer the CH also goes cold.
The CH doesn't work on its own for longer than 2-3 minutes.
Any ideas, I think it might be a faulty 2 port valve on the CH, as the pump works and it works when I manually operate it.
There is also what looks like a bypass pipe with a gate valve from the supply after the pump back to the return pipe to the boiler should this valve be open or closed?
