If you have sludge it is common that a blockage prevents the system filling properly. You can test this by opening the bleed valve on the highest radiator and seeing if water squirts out well (this must be a rad higher than the boiler, the pump and the electric valve to give a confident answer).
If is is not filling you can fill with a hose on a drain-off point.
p.s. if you have a blockage, the cleaning chemicals will not circulate past that point so they will not clear it.
Do you have an Aquavac or other wet/dry vacuum cleaner?
