Please , can someone help me with this one
I installed my own CE system 27 years ago and has given me stirling service until very recently.
IE
Potterton Netaheat 10-16 boiler.
Fully pumped 2way valve system.
LANDIS & GYR RWB2 programmer.
I have recently noticed that the pump doesn't trip out when the CE/HW is programmed to go off and will continually run until I actually switch off the main electrical supply to the boiler !
1) I don't believe there is a pump over-run thermostat fitted to the 10-16 boiler which could have caused the problem.
2) I have actually unplugged the LANDIS &GYR programmer from it's mounting plate and still the pump runs !
3) Could it be the relay unit in the boiler that's gone US ?
4) Could it be a PCB problem within the boiler?
5) Or is it something daft I have overlooked !!
Otherwise the system still runs perfectly . Would appreciate any advice you can give me.
Regards colin
IE
Regards colin
