just a query, Would the central heating pump run without installing it onto the system when a 240v direct supply is put to it without any water passing through?
Yeah it was just a test. With the problems that im having with the heating/hot water i took out the old pump from my system and put a 240v supply to it so i could look inside to see if the blade spun. it was trying to but seemed to be seizing. The blade spins when done manually so this puzzled me hence taking it out to look inside. I think a new pump is in order.
