Hi, first time here so please be patient..
The central heating's not working. Stelrad gas boiler fires up when hot water turned on, but does not fire up when CH thermostat calls for it. Sounded like the thermostat to me so replaced with a new one. Still same problem. Current goes to the stat and the stat clicks when turned and current switches to switch load terminal but boiler does not fire.
Only way to get heating working is to turn on hot water to fire boiler then turn on CH to get radiators warm (and seems to much heat in all rads for it to be simple circulation - but could be wrong of course). Boiler then shuts down when water gets hot enough.
So all seems to be working (programme unit, room stat, hot water, boiler...)except the boiler don't seem to be listening to the room stat.
Any suggestion? What can I check or test - either to repair myself or have some idea of how big a job it would be if I called somebody out.
